Can you id this oil filter, plus 22G190 casing
Se7enthHeaven
Has thanked: 5 times
Post by Se7enthHeaven »
This is on a 69 Cooper S. Been fiddled about with during its life.
I'm used to the old paper filters.
Can anyone tell me what this is?
A Unipart filter but any clue on part numbers so I can get replacements.
Also the gearbox casing is not original. Owner said it wasn't but this is presumably a rarer 970/1071 casing?
Does this mean it's a 3 synchro box?
Re: Can you id this oil filter, plus 22G190 casing
Yep, 3 synchro and VERY desirable for the 1071 owners. 8-)
As for the filter , I'd say this will be correct
https://www.minispares.com/product/Clas ... o%20search
Se7enthHeaven
Cheers Andrew.
Off to Minispares tomorrow to collect a load of parts. (Mustn't forget my mask)
I'll add a couple of filters to the list.
Thought the gearbox might be desirable to small number of people.
To be honest there's no point in the owner having this box on a '69 1275.
Better off with an original box.
Wasn't planning to take the engine out.
I guess these don't come up very often but what's the price difference between a 22G190 and 22G118?
Edited: I meant 22G1128
Last edited by Se7enthHeaven on Tue Jul 21, 2020 10:05 pm, edited 1 time in total.
Certainly a 69 S should have the 4 synchro 1128 box.
I’m probably not the best person to advise about the price difference but suffice to say it is quite a bit. A perfect 22G190 casing (Ie no gears) could easily make £800 + !
Has the gearbox got the Hardy Spicer diff or the rubber couplings that a 190 would most likely have ?
Se7enthHeaven
Not something I've looked at closely but I think they are rubber. Just looked through my photos and can't confirm.
I'll take some pictures tomorrow.
That would be correct for a 190 box but you'd need a Hardy Spicer set up to be correct for the car.
£££ wise, it's better to be this way round than have a 1071 with a 4 sync box and needing a 190 ;)
Se7enthHeaven
Andrew1967 wrote: Wed Jul 22, 2020 8:38 am That would be correct for a 190 box but you'd need a Hardy Spicer set up to be correct for the car.
Totally agree. It's the wrong box for this car. Needs an original 1128 and could make a 970/1071 owner very happy.
A good wrong box to have though and if/when we have the engine out we can put it right.
Se7enthHeaven
Se7enthHeaven
Turns out the gearbox is sitting under an AEG151 block.
Last edited by Se7enthHeaven on Thu Jul 23, 2020 10:18 pm, edited 1 time in total.
Has thanked: 18 times
Been thanked: 51 times
Now there has got to be a story behind this car!!!!
DB1380
Post by DB1380 »
AndyPen wrote: Thu Jul 23, 2020 9:13 pm Now there has got to be a story behind this car!!!!
Just asking. So what would a 151 block normally be found on ? Sounds interesting.
Cheers Dicky.
KPB 729C 65 Mini Minor 1380
Se7enthHeaven
Andrew1967 wrote: Tue Jul 21, 2020 9:51 pm Certainly a 69 S should have the 4 synchro 1128 box.
Rubber couplings.
Also a 12G940 head which is not a surprise compared to the block and gearbox.
That is something a 1071 owner with the wrong engine would love to have... but I am guessing 1071 not 970?
What a discovery!!!
Se7enthHeaven
There's no ally plate to indicate engine size. Owner assumed he had a 1275!
I guess I could roughly measure the stroke through spark plug hole.
Se7enthHeaven
Another anomaly. What's going on here?
I for one have nooooo idea!!!
Hydro cars were often retro fitted with front shockers to stiffen up the ride. To do this, someone would have to add the front shocker mounts.
That S engine is a great find!
