Floor dip switch
colonel mustard
Floor dip switch
Post by colonel mustard »
Hi
The original dip switch Has no identification On which terminal is which. Can anyone advise?
hanlminiman
Has thanked: 20 times
Been thanked: 34 times
Re: Floor dip switch
Post by hanlminiman »
Blue is the power supply. The other 2 are low (blue/red) and main beam (blue/white). I am also working on this and have been checking switches as Mini and mk1/2 Jaguar Lucas switches are different. :D
If you check with a multimeter all should be revealed. Don't forget the rubber mount to the bulkhead under the switch.
Cliff
colonel mustard
Thanks Cliff, as always
Will do some testing, made a rubber gasket for it to sit on, look ok?
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Post by woodypup59 »
Provided you identify the common terminal for the feed wire from the light switch, the other two don't matter.
The dip switch simply toggles between them.
