Hardy Spicer Couplings
piano.paul
Post by piano.paul »
I am fitting Hardy Spicer couplings to a Mini Cooper S with MED pot joint flanges, however when I am putting the engine in the clearance is very tight, therefore, I am trying to work out whether the Hardy Spicer couplings I have are the correct length. Does anyone know the correct length of a Hardy Spicer coupling for the S, or can offer any advice?
jay weinstein
Re: Hardy Spicer Couplings
Post by jay weinstein »
They measure 5 7/16"
Next time it's better to ask questions on Technical Talk....anyway welcome to the forum.
It is always a little bit fiddly getting the hardy spicers lined up. This can be agrivated by not getting the flanges tight home on the gearbox. Make sure the flanges have no more than about 2 or 3 mm clearance between box & flange & the hardy spicer is sliding freely & things should line up OK.
Welcome to the forum too.
jay weinstein
I've got a little more to add......make sure the studs on the flanges are pushed back or removed.
JW
