Creaking rockers
Daz1968
Creaking rockers
Post by Daz1968 »
On my 1962 850 it has the aluminium pillars in the rocker gear,
After I put the car back on the road the rocker gear creaked in operation And I fitted a later set to prove that was the cause, now I would like to refit the originals, anyone know what is likely to cause the noise before I strip them down, car works perfect with a different set so I know it’s the rockers,
Dearg1275
Re: Creaking rockers
Post by Dearg1275 »
It’s probably steel rubbing against abrasive aluminium oxide. Those alloy pillars can crush and cause the rockershaft to be distorted. That won’t help any.
bwaminispeed
Post by bwaminispeed »
They changed them to steel for a reason.........
Daz1968
Post by Daz1968 »
So from what you state am I best leaving the steel one on and just keep the original
Dearg1275
Post by Dearg1275 »
Definitely, alloy pillars are just trouble waiting to happen. It was probably a factory cost saving exercise but quickly got ditched and never appeared on the Coopers which got forged steel pillars. The factory went to using sintered steel pillars on more mundane vehicles.
