Looking for an Exhaust Valve for my 12G295 Head.
Is the C-AEG106 an adequate option?
http://minispares.com/product/Classic/E ... o%20search
In the description they say for 12G940 Head, but will it also work for a Small Bore Cooper Head?
I allready have 29.5mm Valves in this Head, but need replace those...
Many thanks
Fabian
Exhaust Valve for 12G295
- Has thanked: 8 times
- Been thanked: 22 times
Re: Exhaust Valve for 12G295
These valves are of the longer variety at 3.57 inch, the small bore ones are 3.44 inch. If you use a mix of the two lengths you will have problems getting the rocker geometry right.
Okay!
So i allready have inlet valves of 91mm so that's approximately 3.57 inch.
I guess the new exhaust valves work with the new valves
Don't forget, you'll have to pack up the valve springs to get the spring pressure's right........
