Sliding Window Installation
mexran
Post by mexran »
How do I install the front sliding window on a MK1 Austin Mini? Any resources on this?
How do I attach the catch (see picture attached) to the sliding window?
Thanks for any help
timmy201
Been thanked: 40 times
Re: Sliding Window Installation
Post by timmy201 »
How I did it:
Install the top seal to the door
Add the glass and catches to the lower frame rail
Lift the glass and lower rail up and get the top of the glass in the top seal and then get the lower rail in place. Then put the screws in to retain the lower rail
The catch has a screw on the inside, undo that and the catch goes through the glass and the chrome threaded button goes in from the outside
mexran
Post by mexran »
timmy201 wrote: Tue Mar 10, 2020 9:21 pm How I did it:
Thank you for the information. It was very helpful. Cheers.
