I've just dismantled 6 diffs. One of them had bronze washers instead of fibre. Has anyone come across this before? If so do you know if it is better or why?
Differential fibre washer
- Has thanked: 189 times
- Been thanked: 74 times
Re: Differential fibre washer
The early cars up to mid / late 60's has brass thrusts.
The fibre ones are utter rubbish, every diff I've pulled down has at least one gone.
Yes, they are probably brass. They only have a little wear. Would you use then instead of new fibre ones.?
Every time.btetley wrote:Yes, they are probably brass. They only have a little wear. Would you use then instead of new fibre ones.?
I haven't fitted a Fibre type for over 20 years now. They are junk.
The Brass ones are a little thicker and so you need to give the 'button' on the tooth side of the output shafts a lick with a grinder.
- Vegard
If they aren't too worn. You'll know when you assemble them.btetley wrote:Yes, they are probably brass. They only have a little wear. Would you use then instead of new fibre ones.?
I'm going to use a cross diff which I believe has a stainless steel housing compared to the original cast housing. The brass washer should be no problem against the stainless face vs cast iron should it?
- Vegard
It’s not stainless. It’s steel. I think those come with fibre washers. Use them.
