I've removed the wood from my Woody, for some rust repairs.
I've forgotten what mastic / putty I used 25 years ago but it might have been linseed oil based putty.
What do folks use nowadays. Is there anything gun-able ?
I see Screwfix have a silicon sealents in several beige colours which would be a good match for the wood.
Or would a clear one be better ?
mastic for a woody
- woodypup59
- Has thanked: 8 times
- Been thanked: 22 times
- Has thanked: 10 times
- Been thanked: 5 times
Re: mastic for a woody
Can’t speak from experience on woody stuff but the normal silicon sealers don’t seam to last externally. Last time I used that sort of thing was on a Land Rover and I went for a builders mastic.
- LarryLebel
I think the preferred product is 1/4" foam weather proofing tape. That's what came with the wood for my Traveller I got from Somerford.
I used this for my last woody restauration. It stays soft and sticky for many years and give a good seal.
The mastic who is too much you can easy mop up.
I use the same to seal windscreens and sliding window channels and they are absolutely waterproof
Somerford list the tape for sealing the wood. Maybe a bit less messy that squirting sealant everywhere.
Part No. 70 on this link http://www.somerfordmini.co.uk/eshop/in ... page&id=46
Direct link http://www.somerfordmini.co.uk/eshop/in ... ts_id=2024
