cooper s block . two end caps missing
Pedromintor
Post by Pedromintor »
Hi
I Have a thick flange 1275 cooper s block. It only has the centre end cap with it. other two were lost before I bought it.
What is my options ? find second ones and line bore ? or a new set and line bore ?
Any advise would be good.
Thank you
Peter
iain1967s
Re: cooper s block . two end caps missing
Post by iain1967s »
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
I would go for the APT ones with a Set of good ARP Bolts!
I am very happy with my ones...
Has thanked: 189 times
Been thanked: 70 times
You could go either way as a 'fix' but working from new caps will be easier and give a better result.
Charlynsane
Post by Charlynsane »
Pretty much all suppliers will be able to sell you a set of caps. The expense in the operation isn't the caps it's the machining that they will need.
Expect to pay £400 +.
No point just doing 2, do them all, it won't cost any more.
Vegard
Post by Vegard »
Spider wrote:You could go either way as a 'fix' but working from new caps will be easier and give a better result.
What he says!
