Lucas 6RA spot light wiring
sr001
Post by sr001 »
Can anyone clarify the wiring layout for the a Lucas 6RA please?
I have a four pin relay (one has two connectors) marked W1, W2, C1 and C2. I assume they will be ground, 12v power, switched power and lamp power, but I can not remember which is which.
12g295
Re: Lucas 6RA spot light wiring
Post by 12g295 »
W1 is one end of the relay coil
W2 is the other end of the relay coil
C1, C2, are the contacts:
C1 is common
C2 is normally open
Normally open means the terminal is NOT connected to the common terminal
until you flick the switch and send some small power over W1/W2 - Then--->
all the big current flows through C1/C2 and lights up your spotlights :o :o :o
Etienne B.
Post by Etienne B. »
Hi all,
I was about to post exactly the same question,
and I have been "out-posted" by sr001,
great - thanks !!
Etienne
sr001
Post by sr001 »
thanks 12g295
to be clear, and to put it in to my simple english, are you saying:
W1 and W2 are for power in and out, C1 and C2 are the switching side?
12g295
Post by 12g295 »
Yes I think that is what I am saying , but your english is confusing me :lol:
C1 connects to the power
C2 connects to the spotlights
W1 to earth
W2 to the switch and power
(I've edited my post above to make things more clear) :geek:
