30 thou thrust washers
guru_1071
Post by guru_1071 »
just a quick heads up that steel backed ACL brand 30 thou thrust washers are now in stock.
big bore only at the mo, but possible comming in small bore as well. also expect 003 & 005 for both engine sizes soon
12 quid a set plus
no block or crank is scrap any more!
Re: 30 thou thrust washers
Essential when fitting a NON S crank in an S block.
Vegard
Post by Vegard »
mk1 wrote:Essential when fitting a NON S crank in an S block.
But... When grinding them down (as I had to) remove metal from the backside. The bronze layer was extremely thin ;)
Craig
Post by Craig »
And fit them the right way round . Steel back to the block , Bronze to the crank .
Craig
sandman
Post by sandman »
What's needed to fit a S-crank into a 1300 block?
Cheers,
Ed_
Tim
Has thanked: 4 times
Been thanked: 22 times
Post by Tim »
125 thou main bearings?
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
sandman
Post by sandman »
I was thinking in terms of thrust-washers...
Cheers,
Ed_
251 ENG
Post by 251 ENG »
You just thin down std ones to fit S crank in a 1300 block .
Need to loose about 0.030" if everything is STD .
I normally clean up the bearing face first to get it flat , then take the rest off the back ( steel ) side
251 ENG
Post by 251 ENG »
Putting a AEG 480 in 1300 block for my injected 8 port
Crank is 10 on BE and 60 on mains :lol:
Vegard
Post by Vegard »
I've started doing this as well, as the thrust faces are extremely uneven nowadays.
251 ENG
Post by 251 ENG »
Crank re - nitrided and reground at Farndon,s with perfect 0.090" fillet radius .
Well use a crank with good fillet radius (but undersize ) against someting reground by a "moron" to 10/10 with no radius everytime .
I know which one will brake first :lol:
graham in aus
Post by graham in aus »
Hey 251, I thought you'd be grinding your own cranks by now?
Or are you to scared to go near that big heavy machine now? :shock:
251 ENG
Post by 251 ENG »
Hi Graham
Had that crank done years ago .
Got the grinding sorted now , done about 30 cranks now , can keep a good size with nice finish and radius , but I am slow at the moment .
Done a Healey 3000 for a change . :lol:
Vegard
Post by Vegard »
Rich, are the .005s in stock now?
