Cooper S Block
Cooper S Block
Hello, I have an opportunity to buy a Cooper S engine, was wondering if anyone can tell from the attached photo what the bore size is (from the piston numbers)... I don't have physical access to the engine, the seller measured somewhere around 2.780" to 2.800" and perhaps he does have the tools to measure more accurately , so it is not clear to me if it is standard bore or 20 over. Thanks
Re: Cooper S Block
AKM2 has the piston part number as AEG 143.
Standard bore size is quoted as 2.780"
- Toby
- Has thanked: 12 times
- Been thanked: 6 times
Re: Cooper S Block
If the pistons would be over sized that would be stated on them. These are stamped AEG341, to my knowledge those were innocenti 1300 cooper pistons. You will have to check the casting of the block to make sure it really is a S block
T.
- Vegard
Re: Cooper S Block
These pistons are also found in 1300GTs and Cooper Ss.masnarda wrote:If the pistons would be over sized that would be stated on them. These are stamped AEG341, to my knowledge those were innocenti 1300 cooper pistons. You will have to check the casting of the block to make sure it really is a S block
