changing 1960 positive earth car to negative
what's involved with this and what are the benefits?? presumably everything works better?!
- zippypinhead
Re: changing 1960 positive earth car to negative
A decent article can be found here:
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
Edited to add:
The only real "benefit" would be the wider range of accessories available. Not much made anymore for positive ground.
The electron (smoke) in the wires doesn't really care which way ground is.... It's just going around in circles.
Edited to add:
Spot on cheers, just need to find wiring diagram for the car now - couple guys on here have been kind enough to email me some (tks Paul, Ronnie) but i don't think they're quite right, as neither shows floor start switch wired dirct to the battery. Niall.
- Ronnie
- Has thanked: 12 times
- Been thanked: 31 times
It does I have sent the wrong index(I will sort it) 36(battery) 31(starter) 28 starter motor).cookie1071 wrote:Spot on cheers, just need to find wiring diagram for the car now - couple guys on here have been kind enough to email me some (tks Paul, Ronnie) but i don't think they're quite right, as neither shows floor start switch wired dirct to the battery. Niall.
zippypinhead wrote:A decent article can be found here:
Edited to add:
One final question, given i have brand new loom, regulator and refurbished dynamo, do i need to perform the procedure outlined in the link above?
Niall.
