Has anybody else run into the issue that during assembly the pinion gear just won't go on the shaft? Both are new old stock pre A plus items, but it looks like they have been machined in such a way that the fit is too tight. And I don't want to put the pinion on the shaft using a press.
I've tried to fit the pinion to two other shafts too, both of them are new. I did check for burs on both, yet nothing. Think I might need to source a different pinion gear to use, but first of all try with a used one to see if that goes on.
Toby wrote:I've tried to fit the pinion to two other shafts too, both of them are new. I did check for burs on both, yet nothing. Think I might need to source a different pinion gear to use, but first of all try with a used one to see if that goes on.
The Pinions seat on the smaller diameter and so are easily measured. I have a drawing for the Pinions in the office, I'll check (if I remember!) tomorrow (our time) and let you know what the mounting diameter and spline sizing is, so you can check for yourself.
