970s
Posts: 323 Joined: Sat Jun 26, 2010 3:59 am
Post
by 970s » Mon Apr 18, 2016 4:57 am
Hi,
Anyone can help to find a old type HS2 SU AED1310 LH float bowl?
Al
LarryLebel
Posts: 549 Joined: Sat Feb 15, 2014 12:02 am
Been thanked: 1 time
Post
by LarryLebel » Mon Apr 18, 2016 3:30 pm
I would glue the piece back in. Fuel doesn't get that high in the bowl.
Posts: 19835 Joined: Thu Jun 24, 2010 11:30 am
Has thanked: 3 times
Been thanked: 10 times
Post
by mk1 » Mon Apr 18, 2016 3:48 pm
Hi Al,
I'm sure that I will have one.
I'll have a look this evening.
woodypup59
Posts: 1577 Joined: Thu Jun 24, 2010 5:28 pm
Has thanked: 9 times
Been thanked: 23 times
Post
by woodypup59 » Mon Apr 18, 2016 7:27 pm
Epoxy (Araldite) should work but it needs to be fully cured before contact with the petrol.
Where in the world might you be sir ? I have a few scabby 1 1/4" SUs which might yield the float bowl.
tjw89
Posts: 565 Joined: Fri Jul 09, 2010 8:59 pm
Post
by tjw89 » Mon Apr 18, 2016 7:36 pm
I have a box of spare carbs at work, will look tomorrow.
Tim
Ronnie
Posts: 1291 Joined: Fri Jun 25, 2010 5:37 pm
Has thanked: 13 times
Been thanked: 35 times
Post
by Ronnie » Mon Apr 18, 2016 9:03 pm
I think Frost or Eastwoods used to sell what they termed low temperature welding rods (Aluminium) which suposedly welded (more likley solderd ?) even pot metal, it if I remember did not use any flux.
970s
Post
by 970s » Tue Apr 19, 2016 2:01 am
Thanks for your help guys!
Is the LH and RH bowl the same ? cause I see the same part no. on them, the one broken is the RH driver/ flywheel side, and it is the old type without the vertical joint casting mark, seems only found on early twin SU sets!
Al
