Hi, Has anyone a picture of where the floor start switch wires go through the floor panel on a MK1.
Thanks Dave.
Floor Start
Re: Floor Start
If you look on this picture when I was starting the resto on my mk1 you can see the grommet and the wire although it has been cut to remove the loom as I hadn't got access to underside at the time, and was rebuilding the loom anyway,
Re: Floor Start
As far as I am aware the wire I have shown just connects to battery side of the floorstart switch and takes power to the regulator box. The actual switch for starting is a mechanical device and simply connects starter to battery cable when depressed
- woodypup59
- Has thanked: 9 times
- Been thanked: 23 times
Re: Floor Start
What he said.Daz1968 wrote:As far as I am aware the wire I have shown just connects to battery side of the floorstart switch and takes power to the regulator box. The actual switch for starting is a mechanical device and simply connects starter to battery cable when depressed
Its a ~1/4" dia cable, which goes through a grommet above the gear lever. Not the heavy (~ 1/2") starter and battery cables.
