O/S inner wing on a 66 Cooper . Should the larger lower 2 holes be there ?? . I take it the upper ones are for the servo fixing on a S
Thanks Ian
inner wing holes ??
inner wing holes ??
- Hipwell
Re: inner wing holes ??
I had posted a similar thread a short time ago, 1071bob posted a good photo at the bottom. All correct there.
viewtopic.php?f=3&t=14315
Great thank you for the link . Looks like mine has all original holes then
Thanks again Ian
Thanks again Ian
the early snail heater used to bolt in them in the early days maybe they thought not worth modifying the tooling or they had already had amass of them pressed up
My '75 pick up inner wing with the holes - presume they never bothered to update the inner wing pressing for external hinged cars, although a few extra holes are there (solenoid mounting etc)
I think the top larger holes are closer to the top of the inner wing as well ?
- mini63
x 2 Ian.Goldbrocade_62 wrote:the early snail heater used to bolt in them in the early days maybe they thought not worth modifying the tooling or they had already had amass of them pressed up
