7 port head
su_mark
7 port head
Post by su_mark »
I'm thinking of building up a race spec 1293 (maybe 1380) with 7 port head.
There seems to be a few options on the heads. Does anyone have any experience/knowledge/advice?
MED, Webcon, Minisport, Specialist Components, (anyone else?)
Help appreciated.
mzmini
Re: 7 port head
Post by mzmini »
I have seen a Manx 7 porter used on Mervyn Johnson's S on the an Historic Rally on the Isle of Man bloo?y quick well worth considering
Mini Cooper S 1964 Mk1 - International Rally winner red & white
Mini Cooper S 1964 Mk1 - Road Rally champion green & white
Mini Cooper S 1971 Mk3 - original and unrestored
Rubber Sprung
Re: 7 port head
Post by Rubber Sprung »
Mark,you need to speak to Pete Crews or Mike Tarr about making a 7 port fly I've competed in petes and it's awesome .Give me a call if you don't have there numbers, Bob Bennetts
Re: 7 port head
A mate of mine has used the SC one & it works really nicely. The ports are pretty much equal & the standard of finish was excellent. The biggest drawback was it was very soft. I assume it had not been heat treated after machining.
The Minisport / Danish one, has one major flaw the massive difference in inlet tracts between the inner & outer inlets.
I have no experience of the other 2 you mention.
But as has already been said the Manx 7 port always gave superb power, I think there is a certain Beardie weirdy who has a very nice one tucked away somewhere.
I had surprisingly good results from an Alexander 7 port, but finding a good one is almost impossible & they were really designed for small bore engines anyway.
swifty
Been thanked: 43 times
Re: 7 port head
Post by swifty »
I have recent experience of a Manx seven port . I used twin 45s with 36 chokes , 649 cam etc . As for performance what you will notice is the extra torque it gives and just that nice bit of extra grunt when coming out of a corner . ... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
rich@minispares.com
Re: 7 port head
Post by rich@minispares.com »
the big advantage of the manx over the other heads mentioned above is that its legal to use in many applications as its based on a standard casting
a very rare bit of kit
mzmini
Re: 7 port head
Post by mzmini »
Nice bit of kit !!
steve65
Re: 7 port head
Post by steve65 »
Good way to display a couple of DU carbs eh Mark!
Steve.
su_mark
Re: 7 port head
Post by su_mark »
steve65 wrote:Good way to display a couple of DU carbs eh Mark!
Steve.
The thought had never crossed my mind!!
wil_h
Re: 7 port head
Post by wil_h »
The SC head will give the best results. But it is a s Rich says quite soft aluminium. I've used large washers on the head studs to spread the load. Ultimately you end up with a few helicoils in it.
Lakeland997
Re: 7 port head
Post by Lakeland997 »
I'm close to finishing an SC 7-port 1430 build and so far I'm very pleased with the apparent quality of the components.
I can also say that it's pretty pleasing to the eye!
