Does anyone know if a 4223-071 Lockheed clutch master cylinder will fit a Mini ?
Same canister etc but not sure on orientation of tin. Presume push rod is different.
Andrew
A40 clutch master cylinder
Re: A40 clutch master cylinder
Andrew, I am not sure about A40 hydraulics but I will attempt an answer. The bore is 0.75" like the Mini, the orientation is correct but the pushrod is shorter.
I am happy to be corrected.
Thanks Nick, appreciate your reply and I was thinking along the same lines.nick rogers wrote:Andrew, I am not sure about A40 hydraulics but I will attempt an answer. The bore is 0.75" like the Mini, the orientation is correct but the pushrod is shorter.
Will let you know in the next few days
Andrew
Thanks Tom,
I read on the A40 forum that they use Mini ones in the absence of the correct A40 cylinder
Andrew
Andrew
