Flasher Relay
- 111Robin
- Been thanked: 18 times
Flasher Relay
How and where should the relay be mounted on a Mk2 Cooper, considering it has a bulkhead sound deadening mat fitted ?.
Re: Flasher Relay
I'm not sure if the wirings the same as a SDL MK 2, but the flasher on my MK2 just "hangs" in the area between the speedo aperature and washer bottle, underneath the sound deadening mat.
- 111Robin
Re: Flasher Relay
Mine currently hangs as well, next to the fuse box, but I thought it should be screwed to the bulkhead but the mat would make it difficult.
