What size fuel line?
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
What size is standard fuel line? 1/4 ?? Would it matter if I used 5/16? Cheers. Mark
minimans
Re: What size fuel line?
Post by minimans »
Yes and No! Std is 1/4 and 5/16 wouldn't hurt but bare in mind the outlet from the tank is 1/4 and the fuel pump Inlet and Outlet are a 1/4 so really unless you enlarge these at the time of fitting 5/16 there's no benefit either.......................
ianh1968
Post by ianh1968 »
If using both 1/4" and 5/16" in the same system, this hose might be useful:
http://www.carbuildersolutions.com/uk/fuel-hose-7mm-932
I've used it myself with good results - By coincidence, I shall be buying some
more today...
Ian
rolesyboy
Post by rolesyboy »
Thanks folks. I have a roll of 5/16 kunifer on the shelf.
swifty
Been thanked: 41 times
Post by swifty »
I always thought the outlet pipe from the tank was 3/16th but a 1/4 flex hose was used to the fuel pump and from the pump to the front of the car 1/4 pipe . ... I've been wrong before :lol: .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
rolesyboy
Post by rolesyboy »
Anybody want to go any lower?? :lol: :lol:
Confused from Essex!
smithyrc30
Post by smithyrc30 »
The standard outer diameter as far as I recall is 1/4", which means with the pipe wall thickness the bore is 3/16".
A far cry from a 1965 Ford Galaxy 500 I had which ad 1/2" fuel lines....
ianh1968
Post by ianh1968 »
smithyrc30 wrote:The standard outer diameter as far as I recall is 1/4",
In "old money", the bore was always quoted as the size...
For example a 1/4" BSP fitting would be the one to use with a 1/4" BORE tube.
However:
When "Metric" came along, particularly in domestic plumbing, it WAS the OD
that was quoted as being the pipe size.
This is why 1/2" plumbing tube is almost the same "size" as 15mm tube...
Conclusion:
The pipe with an outer diameter of 1/4" should probably be called 3/16" pipe!
Ian
