I am in process of restoring a mk2 cooper and it has had repairs in boot floor before and I need a little info about the mounting to floor of the tank straps, is there a captivated nut in the floor for this and if so anyone have any pictures, also my car has a genuine right hand tank that I presume was fitted later, would this have a captivated nut or would it simply be drilled through floor and bolted, the bulkhead mounting is bolted unlike the lefthand side which is spot welded to bulkhead,
Tank strap mounting
- minimans
Re: Tank strap mounting
Well I'm sure its a "Captive" nut on the left tank! on the right my 68 S has a non-captive nut and yes the bulkhead bracket is bolted on with 1/4 nuts and bolts.
- Been thanked: 38 times
The left hand side has a bracket 14A 6565 with a captive nut+cage spotwelded to it. The original factory spec twin tank cars had a smaller captive nut bracket fitted on the RH side. I made my own RH bracket to match the other side. The holes in the boot floor are in the same position both sides.
Mine is missing after a replacement bootfloor (no evidence of it on the old one!) even if its wrong I strongly suggest you fit one! It's a pig of a job without a captive down there.
Nick
Nick
