151 block ?
mk1mad
151 block ?
Post by mk1mad »
i have a block with 74.5 pistons 177 rods is it a 1071 over bore and could it be relined there is not alot of meat left between bores
thanks
360gts
Been thanked: 37 times
Re: 151 block ?
Post by 360gts »
If it has the AEG151 casting on it...then it is a 1071.
nick rogers
Re: 151 block ?
Post by nick rogers »
Or a 970.
mk1mad
Re: 151 block ?
Post by mk1mad »
it also has a cross drlled crank with aeg 1053 cast into it
360gts
Re: 151 block ?
Post by 360gts »
970 is AEG131.
251 ENG
Re: 151 block ?
Post by 251 ENG »
970 crank is AEG 330 , 1071 is AEG 171 :ugeek:
Has thanked: 125 times
Been thanked: 34 times
Re: 151 block ?
mk1mad wrote:it also has a cross drlled crank with aeg 1053 cast into it
My records here are not complete, but according to what I do have, it appears that there wasn't a Cross Drilled Factory Crank made for the 970 or the 1071.
Can anyone confirm this?
That said, I also don't have a listing for an AEG1053 Crank either.
