Oh S#!t!!!
Chalkie
Oh S#!t!!!
Post by Chalkie »
Err I think i just made a massive balls up on my 12g202 head
trying to remove what was left of the water by pass tube, with an easy out as i started to undo it after heating it with lots of atf/kerroncine mix and having to use a bar to move it, there was a massive crack noise it free'd off but it also took a chunk out my head. Annoy and feel stupid
CAN THIS BE FIXED?
thanks
Stephen
Re: Oh S#!t!!!
If I was you I'd get it brazed up & drill about 6 1/8" diameter holes in the thermostat to act as a bypass & call it quits.
Chalkie
Re: Oh S#!t!!!
Post by Chalkie »
Do you need the by pass though?
and okay that sounds expensive :(
thanks
Stephen
Re: Oh S#!t!!!
The holes in the thermostat do the same job as the bypass hose, by allowing a small amount iof water to circulate before the thermostat has opened. It shouldn't be very expensive to get it brazed up, maybe £30 or so.
Or a new head shouldn't be too expensive.
http://www.ebay.co.uk/itm/Classic-morri ... 20f6c6e98d
Chalkie
Re: Oh S#!t!!!
Post by Chalkie »
Okay thanks
I did have a look on ebay, head i have has already been unleaded converted I was just gonna have valve seats recut and then new guides
Hmm wonder now if to look out for a 295 head.
thanks
Stephen
Re: Oh S#!t!!!
A 295 is a massively better option than any 202.
Chalkie
Re: Oh S#!t!!!
Post by Chalkie »
mk1 wrote:A 295 is a massively better option than any 202.
and put massive holes in pockets. This head was a swop for a HIF44 carb i had laying around so affectively cost me £0
medwaybeat
Re: Oh S#!t!!!
Post by medwaybeat »
Have you considered gluing it. I know it sounds a bodge.
Proper slow setting Araldite might be an option or JB Weld high heat.
Super glue is great for cast iron but not really suitable for high temps.
251 ENG
Re: Oh S#!t!!!
Post by 251 ENG »
You have a PM
rich@minispares.com
Re: Oh S#!t!!!
Post by rich@minispares.com »
you didn't go green and tear all your clothes off at the same time did you?
that's quite an impressive bit of damage to do just from riving at it! :lol:
Chalkie
Re: Oh S#!t!!!
Post by Chalkie »
rich@minispares.com wrote:you didn't go green and tear all your clothes off at the same time did you?
rich if i brake something I normally do a good job of it haha
