Formula Junior/1071S myths (revisited)
Toby
Post by Toby »
I thought it might be useful to dig up this old thread on the myths regarding the 1071 engines that was started on the mk1, mk1 forum : http://www.atfreeforum.com/phpbb/viewtopic.php?t=2000
Recently I managed to find a block for my own mini but I was surprised to find a extra letter on the outside of the block. ( Many, many thanks to Oliver, Christiaan, Bart and Nick for helping me out on obtaining it! )
Here are some pictures of it as it is now:
What I've never seen before is the extra letter B near the opening for the dipstick.
Caps are also number with an E:
Any body got any details on this?
T.
Mini4Ever
Re: Formula Junior/1071S myths (revisited)
Post by Mini4Ever »
masnarda wrote:( Many, many thanks to Oliver, Christiaan, Bart and Nick for helping me out on obtaining it! )
It did travel quite an unlogical route before it ended up at your place :D
Too many cars...
251 ENG
Post by 251 ENG »
The caps are not the originall,s and they are the wrong bolts .
Does the block have a dry sump pump hole and the little boss for the 1071 tag on back ?
Toby
Post by Toby »
there is a little boss to mount the tag on the back, no hole for the dry sump pump and I do have correct bolts for the block, these are just the ones that came with it.
What type of engine would the caps belong to then?
T.
251 ENG
Post by 251 ENG »
Hello
The blocks not a very early one then , should have a number starting with C stamped by water pump . I would guess between C 1300 and C 2500.
Caps are off a late 1275 s block , probably a thick flange one .
Toby
Post by Toby »
The block is meant for my august 63 built S. So it doesn't have to be that early I guess. However I have never seen the letter B cast in before. Will have to check to see if there are any numbers near the water pump.
T.
