Steering Rack fitment on Mark 1
billycooper
Post by billycooper »
Can someone explain to me the ins and outs of fitting a new later type steering rack to a Mk 1 ?
Do the splines fit the Mk 1 Column ?
And can i use the Mk 1 Steering arms ?
Steve "Murph"
Re: Steering Rack fitment on Mark 1
It is a straight swap, column etc match. But you do need to change the steering arms to match the rack.
billycooper
So in other words, (for the educationally challenged like myself !) i need to fit later steering arms ?
thanks Mark
Steve "Murph"
rich@minispares.com
Post by rich@minispares.com »
yes, otherwise the akerman is all wrong and they steer like a pig!
Exactly.
A MK1 Rack uses MK1 steering arms.
A MK2 on rack uses MK2 on Steering arms.
They can be easily swapped over by removing the two bolts in the top of the hub, swapping the arms & replacing the bolts remembering to replace the lock washers at the same time.
billycooper
Cheers chaps, thats great :)
Steve "Murph"
newtune
Post by newtune »
Rich can u get mk2 S arms ?
james
Has thanked: 206 times
Been thanked: 79 times
There was a bit of a discussion on this subject here;-
viewtopic.php?f=3&t=7126
The MKII Thick Arms, as also fitted to the S are available;-
https://www.minispares.com/product/Clas ... o%20search
