Lucas SFT576
swifty
Been thanked: 38 times
Lucas SFT576
Post by swifty »
Hi . Going to be fitting 4x Lucas SFT 576 spots and fogs to my on going project . It's not a rally project or anything just road car . Is it ok to just wire these into the main beam loom . I will be fitting a alternator . .... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
captain
Re: Lucas SFT576
Post by captain »
you will have to wire them through a relay or you will burn your switch out,fire hazard
LarryLebel
Re: Lucas SFT576
Post by LarryLebel »
I had LR6s wired via a relay into my high beams. My lights have covers so whenever I needed the high beams I would have to take the covers off which was a PITA. I rewired the spots on a dedicated switch.
Tim
Has thanked: 4 times
Been thanked: 23 times
Re: Lucas SFT576
Post by Tim »
Out here its a legal requirement that spots must have a seperate switch and dip (turn off) when the high beam dips, so their relay is energised by the high beams, but only when switched on.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
JC T ONE
Re: Lucas SFT576
Post by JC T ONE »
Tim wrote:Out here its a legal requirement that spots must have a seperate switch and dip (turn off) when the high beam dips, so their relay is energised by the high beams, but only when switched on.
Tim
Same here in Denmark, and fog lights can only work with either side/ lights or low beam, they must turn off when high beam is on.
Ronnie
Has thanked: 13 times
Been thanked: 35 times
Re: Lucas SFT576
Post by Ronnie »
If your lights were below 24" centre hight in the UK it used to be (and I believe still the case) they can only be used in fog or falling snow there are also limitations on the distance between lighted surfaces, which used to be pointed out when you purchased a ST lamp bar. If your lights are above 24" you can use on the road but they must only be used with main beam and extinguish when you dip your headlights. :o 8-) On a forrest road you can switch them all on. :)
rich@minispares.com
Re: Lucas SFT576
Post by rich@minispares.com »
what ever combination you use, a relay is a must
the switches and stalks get mighty hot if you don't!
swifty
Re: Lucas SFT576
Post by swifty »
Thanks everyone . ...ken
Porsche 997 turbo S
I am from Essex
