Wanted a "Clutch Specialist" to re-build a coil spring clutc
Can anyone please recommend me a Clutch Specialist that may be able to help.
- gs.davies
- Has thanked: 14 times
- Been thanked: 30 times
Re: Wanted a "Clutch Specialist" to re-build a coil spring c
They're fairly simple devices to be honest - when I did mine (about twenty years ago) I don't think there was much to it. You just need a tool to decompress the coils.
Ok, I'll give it a go then.
I have been lucky enough to find an original clutch kit, my only concern now is the balancing the clutch plate
As long as you match all the little stamped "A"'s up on the back plate, the flywheel & the diaphragm you can't go too far wrong.
