Wanted a "Clutch Specialist" to re-build a coil spring clutc
Sceptre123
Post by Sceptre123 »
Can anyone please recommend me a Clutch Specialist that may be able to help.
gs.davies
Has thanked: 14 times
Been thanked: 30 times
Re: Wanted a "Clutch Specialist" to re-build a coil spring c
Post by gs.davies »
They're fairly simple devices to be honest - when I did mine (about twenty years ago) I don't think there was much to it. You just need a tool to decompress the coils.
Sceptre123
Ok, I'll give it a go then.
I have been lucky enough to find an original clutch kit, my only concern now is the balancing the clutch plate
As long as you match all the little stamped "A"'s up on the back plate, the flywheel & the diaphragm you can't go too far wrong.
