Red Shed the 68/69 mk2
roger mcnab
Re: Red Shed the 68/69 mk2
Post by roger mcnab »
hi
the things we go through in the quest for more power and speed yes 2 belts some how fit in that space a friend here in australia has that set up in his mini and it looks tight in the pics that he sent on his phone
works very well so keep at it and it will happen would help to see it in real life
cheers roger mcnab :evil: :evil: :D :D
Dr S
Post by Dr S »
Right then. The bottom pulley is fitted. Seems a bit of a faff until you remember it’s a mini not the vee dub and just accept that the engine mounts coming out etc etc.
So the bottom pulley is fitted...
That gave me a datum for the top, and a measure on the belts. So we have two 1050mm a belts on order.
Going up the top then. The mini manifold is the right shape.
Dropping it on the freeflow shows the issue, it’s just too much of an intersection between the freeflow and the cast manifold.
I think I’ll bell maniflow tomoz and see if we can get a steel version of the manifold made, or possibly that the lcb drops down faster so we’d have much less to cut out the cast manifold so it has half a chance it will survive. FWIW this is one a mate has been doing to get to clear
Dr S
Post by Dr S »
Shots from a mate - mk1 cast manifold trimmed to clear a freeflow. The problem is perhaps apparent...
Dr S
Post by Dr S »
This weekends progress! Brought to you by a sharpie...
Some 10mm steel plate and a 35mm mandrel bent pipe.
A new dremel and a 25mm hole saw.....
Dr S
Post by Dr S »
Hmm bought a lathe and built a steam engine. I do get distracted sometimes.
Tommorow a box of goodies from maniflow should arrive. A fabricated steel inlet and a custom lcb centre pipe to help clear. That should get us fitted and flowing well...
Ha, ha, it must be catching. . . . .
Not actually mine, but it appeared in my shed while I was away :lol:
roger mcnab
hi
that scene reminds me of the movie the iron maiden all about racing traction engines
cheers roger :lol: :lol:
Tim
Has thanked: 4 times
Been thanked: 23 times
Post by Tim »
Issigonis was working on a steam mini in the early '70s. Time to take up the reins and finish it off?
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
