Barbon Hillclimb 7th July
Pete
Has thanked: 39 times
Been thanked: 102 times
Re: Barbon Hillclimb 7th July
Post by Pete »
Entry was still open Mark, but the booking system had crashed. I did check with Jackie. Once it was fixed it closed! :lol:
No biggy, it was very last minute.
rich@minispares.com
Post by rich@minispares.com »
Pete wrote:Entry was still open Mark, but the booking system had crashed. I did check with Jackie. Once it was fixed it closed! :lol:
get yourself entered into the montegue burton pete
it will be great to see you out in your car
Nick W
Post by Nick W »
App K wrote:GUTTED
just rolled the cooper out of the garage for a spit and polish to take the daughter to the prom on Friday night and “kerchunk” from the inner bowels of the gearbox?
Eh? Tried to engage gear and it whent backwards then would go forward and then stop after 3 ft as the gearbox locked up...so goes (rolls) backwards and rolls forward a few feet and locks up. Gearbox fucked.
Brilliant :cry: . Was really looking forward to Barbon and haven’t got the time to pull it apart for then. I have been thrashing the bejayzus out of the car virtually every night for the last couple of weeks on the local moorland roads, but I can’t beleive that I drove it in the garage and it broke when I rolled it out? I suppose I might be lucky in that respect.
Still effin gutted though.
my S once locked up ...pulled engine and found starter ring had half come off locking it up :? worth a check
Up North in Sheffield
Pete
Post by Pete »
I'm on it! :D
App K
Post by App K »
my S once locked up ...pulled engine and found starter ring had half come off locking it up :? worth a check[/quote]
Hmm.good advice but the Engine starts and runs fine and you can select reverse and the car will go back a few feet. No drive in any forward gears but if you push it forward it will roll a few feet then lock up solid. It basically will push backwards and forwards for one complete revolution of the wheel and locks solid.
Might see if I can get the 970 ready for Saturday, not many days at Barbon when the sun shines.
rich@minispares.com
App K wrote:my S once locked up ...pulled engine and found starter ring had half come off locking it up :? worth a check
Might see if I can get the 970 ready for Saturday, not many days at Barbon when the sun shines.[/quote]
its not spat the diff pin out has it?
App K
Post by App K »
its not spat the diff pin out has it?[/quote]
Quiafe ATB.
Just wondering if its sheared a bolt on the crown wheel. There’s not a lot of space between the straight cut crown wheel and the diff housing, it took a lot of machining out the casting to get it to fit.
rich@minispares.com
or a bolt has wound out, its odd that's its doing almost a rotation, but a bolt might be making its way 'almost' round the case and getting stuck on a high spot
id drain the oil out and see what prizes you have won! :lol:
App K
Post by App K »
rich@minispares.com wrote:or a bolt has wound out, its odd that's its doing almost a rotation, but a bolt might be making its way 'almost' round the case and getting stuck on a high spot
First thing I did. The usual magnetic fuzzy stuff with a mixture of metallic finger nail clippings. :?:
Don’t understand how I could have reverse drive but nothing forward unless that was the quiafe playing tricks on me.
Anyway if I don’t get to Barbon..out it comes.
billycooper
Post by billycooper »
Cracking day at Barbon, weather was awesome, my previous best Mini time was 32.03, and got down to 32.73 in a far less powerful DJJ and Nick on 34.09, hes coming for me !!
Shame Brian didn't make it, so we had to compare times with the classic car class all day and we were there or there about with the top few times
DJJ still cocks a rear wheel for fun, ive some red spot donuts to go on the front and some Hi Los for Harewood in August, stuck an entry in last night and hope we get one !
http://www.whitedogphotography.co.uk/pa ... all_id=233
My father hasn't been on top form for a few good year's and he managed to make it, so 3 generations of competitive Mini Murphy's at Barbon !
Steve "Murph"
IAIN
Post by IAIN »
great picture, one for your album. If they still exist. :)
Cracking Photo Steve!
You were certainly trying :)
billycooper
mk1 wrote:Cracking Photo Steve!
How was Harewood Mark ?
Steve "Murph"
billycooper wrote:How was Harewood Mark ?
A bit odd.
Started off Ok, both Adam & I got our 2 practice runs in without incident.
Adam's first timed run, he hit the dragons teeth coming out of Chippy's & lost a tyre, so he had a fail, & I got a fail to start. I went home to get some more tyres, but by the time I got back Adam had fixed it.
Second run, Adam did a 70.07 & I did a 69.59, but we didn't swap the numbers over so I got no time again,
3rd run both went Ok, Adam did a 70.16 & I did 69.87
Adam finished 3rd in class (on my time)
A finished second from bottom only recording 1 time for the day :(
Still, no harm done & we both live to fight another day.
billycooper
A bit odd.
Really Cracking times Mark, I'm still struggling to break into 73 ! , I had a quick look at the results and wondered what had happened!
Steve "Murph"
rich@minispares.com
it was also RED FRICKING HOT
trevorhp
Has thanked: 10 times
Post by trevorhp »
A bit odd.
Bizarre but strangely satisfying day by the sound of it
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
6604KF
Post by 6604KF »
Seen a picture of your hornet with arches and slicks. How were they?
6604KF wrote:Seen a picture of your hornet with arches and slicks. How were they?
Ha, ha, don't tell Steve I was on slicks, I was wanting him to wonder how I had knocked 2 secs off since the last meeting :)
They were frickin' great! I reckon there is probably another second & a half to come yet too :)
I would love to see a pic, I haven't yet.
6604KF
Post by 6604KF »
Great! There’s a picture on phill Andrews Facebook page.
