No biggy, it was very last minute.
get yourself entered into the montegue burton petePete wrote:Entry was still open Mark, but the booking system had crashed. I did check with Jackie. Once it was fixed it closed!![]()
my S once locked up ...pulled engine and found starter ring had half come off locking it upApp K wrote:GUTTED
just rolled the cooper out of the garage for a spit and polish to take the daughter to the prom on Friday night and “kerchunk” from the inner bowels of the gearbox?
Eh? Tried to engage gear and it whent backwards then would go forward and then stop after 3 ft as the gearbox locked up...so goes (rolls) backwards and rolls forward a few feet and locks up. Gearbox fucked.
Brilliant. Was really looking forward to Barbon and haven’t got the time to pull it apart for then. I have been thrashing the bejayzus out of the car virtually every night for the last couple of weeks on the local moorland roads, but I can’t beleive that I drove it in the garage and it broke when I rolled it out? I suppose I might be lucky in that respect.
Still effin gutted though.
I'm on it!rich@minispares.com wrote:get yourself entered into the montegue burton petePete wrote:Entry was still open Mark, but the booking system had crashed. I did check with Jackie. Once it was fixed it closed!![]()
it will be great to see you out in your car
App K wrote:my S once locked up ...pulled engine and found starter ring had half come off locking it upworth a check
its not spat the diff pin out has it?[/quote]rich@minispares.com wrote:App K wrote:my S once locked up ...pulled engine and found starter ring had half come off locking it upworth a check
Hmm.good advice but the Engine starts and runs fine and you can select reverse and the car will go back a few feet. No drive in any forward gears but if you push it forward it will roll a few feet then lock up solid. It basically will push backwards and forwards for one complete revolution of the wheel and locks solid.
Might see if I can get the 970 ready for Saturday, not many days at Barbon when the sun shines.
First thing I did. The usual magnetic fuzzy stuff with a mixture of metallic finger nail clippings.rich@minispares.com wrote:or a bolt has wound out, its odd that's its doing almost a rotation, but a bolt might be making its way 'almost' round the case and getting stuck on a high spot
id drain the oil out and see what prizes you have won!
mk1 wrote:Cracking Photo Steve!
You were certainly trying
A bit odd.billycooper wrote:How was Harewood Mark ?
mk1 wrote:A bit odd.billycooper wrote:How was Harewood Mark ?
Started off Ok, both Adam & I got our 2 practice runs in without incident.
Adam's first timed run, he hit the dragons teeth coming out of Chippy's & lost a tyre, so he had a fail, & I got a fail to start. I went home to get some more tyres, but by the time I got back Adam had fixed it.
Second run, Adam did a 70.07 & I did a 69.59, but we didn't swap the numbers over so I got no time again,
3rd run both went Ok, Adam did a 70.16 & I did 69.87
Adam finished 3rd in class (on my time)
A finished second from bottom only recording 1 time for the day
Still, no harm done & we both live to fight another day.
Bizarre but strangely satisfying day by the sound of itmk1 wrote:A bit odd.billycooper wrote:How was Harewood Mark ?
Ha, ha, don't tell Steve I was on slicks, I was wanting him to wonder how I had knocked 2 secs off since the last meeting6604KF wrote:Seen a picture of your hornet with arches and slicks. How were they?
