Maniflow inlet manifold thoughts
Cheeser
Post by Cheeser »
I have a maniflow inlet manifold which is currently used with 2 x hif44 (1 3/4inch) SUs. I intend to use this manifold on a different engine but using Hif4s (1 1/2inch) SUs, what is anyone's experience and/or thoughts on the slight "step" going from 1 1/2 carb to 1 3/4 manifold? Thanks for any advice that you are able to give.
GraemeC
Re: Maniflow inlet manifold thoughts
Post by GraemeC »
Your proposed set up is exactly what I use and don't have a problem. I did use 1" long x 1.5" bore plastic (phenolic?) isolator blocks and ported these out so they were graduated from 1.5" to 1.75"
Cheeser
Post by Cheeser »
Thanks for that,I was just considering if it was best to do as you have or whether to just leave the step.
