6 off screws and a cork gasket... (and no instructions).
I've worked out that the screws are 8-32 UNC by 3/8" long.
I can get some stainless versions.
I have also seen, but not got, some copper washers...
What is the correct method of assembly? It's for a Mini-Marcos
and it will be very difficult to sort out if it decides to leak when
I fill it up. I'd like this to not be the case.
Do I "goo" the gasket to the sender, then stick it in with some
grease that will get dissolved by the fuel, or what?
Help Please!
