Engine build ponders
Evening chaps
Sending my engine for an overbore next week
now I have a few questions about it
should I get the block drilled and tapped out to 5/16ths?
Get them to fit cam bearings or do it myself
also its using an A+ Block as my a series is sleeved and no good for performance use
should i run megajolt or run a swiftune dizzy?
thanks
Steve
thanks
Steve
- Has thanked: 18 times
- Been thanked: 11 times
Re: Engine build ponders
I'm told that the 5/16 conversion isn't necessary with a thick flange block.
I've just done cam bearings myself and it really wasn't a problem, but I did make top hats to go inside the new bearings. I have to say that I did give them a bit of a tap to get them started square but they pulled in easily with some stud bar.
- Nick W
I'd get your engine shop to do the cam bearings , I screwed up trying to fit mine! .
Up North in Sheffield
- rich@minispares.com
Drilling it 5/16 is a waste of time unless your building some huge stroke 1460 that's really going to tug the block around. Its also a huge pain to bolt a 5/16 block to a gearbox unless you use caphead screws as you can only get about half a turn of a flat each time so it takes forever to do the nuts/bolts up (if you use normal ones)
Verdict:- pain in the arse!
- LarryLebel
There's more to it than just installing the cam bearings. They also have to be reamed to size which I'm guessing you can't do.
- Been thanked: 9 times
I install my own cam bearings but did go to the trouble of making a kit from 1/2 inch all thread and alloy plugs. I can either tap them in or pull with the threaded rod. Not since 1969 have I seen a cam bearing that needed reaming to size after install. They are all sized now. I use 5/16 allen caps grade 8 for race units that turn big revs. For street I use 1/4 grade 8 allen caps with high collar locs and SAE flats. If you do go 5/16 you will need to drill the tranny case to clear. Steve (CTR)
Thanks so ill take off doing 5/16th convertsion then
but gonna be running around 50-60bhp depends what clutch plate would you lot reakoment as having everything balanced aswell
thanks
Steve
thanks
Steve
- Been thanked: 10 times
NO, Total waste of time & a pain in the arse too.
Get them fitted by your engine shop then they can hone them to size.
Don't know. I have no experience of either.
Use a "Rally" Orange diaphragm, a good all rounder. A standard plate should be fine.
Definately get the whole lot balanced.
Orange rally plate isn't gonna make my thrust bearings shit them selfs is it?
thanks mark Ive been looking at the CSI dizzy my a series dizzy got nicked and never had an A plus one
- Has thanked: 206 times
- Been thanked: 79 times
Personally, I only ever like to run with the diaphragm that will get the job done and no more.
Given your anticipated HPs, a stock Blue Cooper S one I'd say would be fine.
Nice one thanks
Last question then having everything balanced will they need my pressure plate and clutch plate or can I get away with sending fly wheel backing plate crank and that?
best to send it all
they certainly need the pressure plate as it bolts to the crank
the clutch disc isn't that important as it moves independently, so doesn't affect anything
A Blue would probably be fine, but an Orange one will certainly not have any detrimental effect. It's only marginally stiffer than the standard one.
ill order an orange as I can't find a Blue on Minispares
and then send it all in as one lot
just pulley now to sort i got 4 of em just witch one to use
what about pulleys
getting it all balanced whats rekonmaneded ?
I will be superchargering after ive ran the engine in
thanks
thanks
Hi need some help new to engine builds
Just purchased a block
Bored and new pistons plus 60
1330
But the camshaft marking is one raised ring
Is the cam ok for good performance
Also looking at carbs single hif 44
1330
- Vegard
I agree. I've used blue diaphragms on 1400, 286 engines. That did almost work
No small bore should ever be fitted with an orange diaphragm. Sorry Mark
Is the cam ok for good performance.
NO, its probably a standard A+ cam
Must disagree re the orange Diaphragm on a 998, I know that the thrusts are a bit narrower than on an S or 1300, but particularly if Chalkie is thinking about supercharging it will be better than a standard one.
Wil Ker uses a GREY on on his Turbo 998 & has not had issues with thrusts collapsing.
mk1 wrote:But the camshaft marking is one raised ring
Cause he has a lighter flywheel set up on it
dropped the block off at the shop so hopefully it be ready to rock and roll soon need to get ordering up bits to get everything balanced
The weight of the flywheel will have no effect whatsoever. The issue is the clamping force placed on the thrust bearings by the clutch diaphragm spring this is unaltered regardless of the flywheel weight.
