Assistance please
Mini me
Assistance please
Post by Mini me »
Good evening Gentlemen.
Can anyone help identify this Dash & Block?
Sorry if the information is vague, I can upload more engine photos when it comes apart.
Thank you in advance.
Andrew1967
Re: Assistance please
Post by Andrew1967 »
Looks like a small bore 998 block that's been pocketed and extra holes drilled to take a 1275 S or 1300GT head. Steel centre main strap as well.
I've got a 998 Cooper block just like that.
Never seen the core plugs strapped like that though :o
LarryLebel
Post by LarryLebel »
Block is A+. Core plugs are in ass-backwards. The crank looks like a billet crank.
Has thanked: 206 times
Been thanked: 79 times
LarryLebel wrote:Block is A+. Core plugs are in ass-backwards.
Bhahaha, now I don't feel so lonely! Have another look Larry - with the glasses on (I'll gladly lend you mine!)
It does appear to be a Late Pre-A+ Small Bore Block.
LarryLebel wrote:The crank looks like a billet crank.
Hard to say for sure from those pics, I thought the same at frst, but now I look again, just looks like a modded stock crank, the rods look to be a special too, or modified S rods?? (again, hard to make out for sure).
Too bad it's been butched by cutting the eyebrows in the deck (for the bog bore head :roll: )
coop12g295
Post by coop12g295 »
Not A + as that would have the boss lower right for the distributor clamp
and the dynamo/alt bracket tappings nearer to the front of the block
251 ENG
Post by 251 ENG »
Block is A series 998 , not A+ .
Crank is a forging modified / manufactured by Farndon Engineering and could well be EN 40B
Rods are probably cooper s
Looks like an old 998 mini miglia engine
graham in aus
Post by graham in aus »
Agree, What Simon Said ^^^^
Miglia before they went to 1300, probably high compression! :mrgreen:
S Rods may have been thinned at Big End to fit ? :ugeek:
LarryLebel
Oh well ... you win some but lose the rest.
Mini me
Post by Mini me »
Thanks for the help Gents.
Anything on the dash.
Regards
Been thanked: 10 times
Post by Old English White »
BMC Comps Dept used to fit straps across the core plugs. I had an engine "out of the back door" once :o
skorwxe
Post by skorwxe »
Yes, BMC Comps did this as I have seen it mentioned in a build sheet.
