A-panels... Heritage or M-machine??
sandman
Post by sandman »
I need to change some A-panels on a Mk1;
What to buy? Heritage or M-machine.
Which is the better fit?
Also; would the heritage frontpanel - 14A8308 - be suitable for a Mk1 or does it got alot of the modern bits'n holes?
Cheers,
Ed_
rich@minispares.com
Re: A-panels... Heritage or M-machine??
Post by rich@minispares.com »
the 14a8308 is ok, the worse thing is the 'wrinkle' at the front where heritage put the insert in the press to convert the mpi pressing to the early one.
it takes work to dolly it all out and fill it, so its a cost to consider.
the mini machine ones, or the cheapy magnum ones are as good, the pressing is certainly 'cleaner'
'long beard boss'
STG95F
Post by STG95F »
100% M-Machine , buy the Outer A-Panel with part of the pillar and door step in one . Not cheap but very good .
Been thanked: 10 times
I bought a Heritage front panel for the Speedwell car & my tin man sent it back & swapped it for a cheapo one because the cheapo one fitted better & needed less work to make it right.
As far as A panels are concerned, I don't see much difference, they both need a lot of fitting to work properly.
STG95F
Post by STG95F »
Very True about the A-panels . They all need work , just found m-machine easier to work with like the Front panels
Its a joke really you would expect Heritage to be a lot better than they are :oops:
coop12g295
Post by coop12g295 »
I'm with stg95f m Machine 'a' panel with the 'a' post is a good panel and minimal hassle
STG95F
Post by STG95F »
sandman
Post by sandman »
STG95F wrote:100% M-Machine , buy the Outer A-Panel with part of the pillar and door step in one . Not cheap but very good .
Is this the one;
11.14.00.87 Door Pillar & Apex Panel, LH, Mk1-2, Van & Pick-Up 76.50 £91.80 ?
Any one know if they got the complete RH innerwing that incorporated the inner A-panel with hinge-brackets etc?
And if they do... is it a good fit?
Many thanks,
Cheers,
Ed_
In the shed
Post by In the shed »
My mini wears M Machine sills.
They are beautiful.
STG95F
Post by STG95F »
I don't think they do . I had a Heritage Inner wing and it was total crap i did more cutting and welding just to get it to fit and it was never right .
Do you need a full inner wing or just part ? Try repairing your original ??
sandman
Post by sandman »
Seems like M-machine might be "out" of their inner A-panels...
So question now if what to go for;
Heritage or any other option... Magnum?, "minispares nongenuine" ? whatever.. ?
Anyone care to weigh in?
Cheers,
Ed_
As I said before;
