Wheels for competition
bluemin
Post by bluemin »
First a few ground rules:
1) Alloy wheels are the ones in question
2) No Rosepetals (Too expensive for my tastes)
3) Must fit over KAD 4 pot calipers
4) Size is 5 X 10
5) Tarmac rallying
Are Minilites worth the extra? Are the Minilifes OK? Certainly cheaper.
Not too keen on Superlights/Minilights/Revolites/Starmags
Any comments, suggestions or offers of cheap good wheels gratefully received. :)
InimiaD
Re: Wheels for competition
Post by InimiaD »
7.5 or 7.9 inch discs.?
bluemin
Post by bluemin »
Ventilated 7.9.
InimiaD
Post by InimiaD »
Hmmm. The choice just shrunk.
One of the lads in my local club has roughly the same brake set-up and he struggled to get wheels.
He wanted genuine Minilites, but for some reason they wouldn't fit over the calipers.
Time for some enquiries methinks.
InimiaD
Post by InimiaD »
Homework completed.
He ended up putting Minator 10x6's on his car. The Minilites would not fit over the 7.9 4 pots because," the manufacturers had changed the casting slightly"
The 4 pots were not KAD items though.
JC T ONE
Post by JC T ONE »
Hi :)
I have 7.9 vented, with K.A.D 4 pot alloys, and use 10" Revolution, fits perfect.
Jens Christian
bluemin
Post by bluemin »
It's on genuine Minilites at the mo but these are OLD Minilites & not the current "model" Can't see any ET marking though.
Minatots are certainly a possible. I've used them before (Non Mini) & found them fine. I assume that we're talking here about current Revolutions & not the imitation Revolite. Incidentally are those the road, race or rally versions?
Thanks in the meantime.
Been thanked: 10 times
I THINK this set up will fit under Minilifes, if they do, use them. Best wheel for its price on the market.
Give Minispares a ring to check.
bluemin
Post by bluemin »
OK tried Rich & he has absolooootely no idea if their 5 x 10 Minilife will fit over this set up. He also suggested that going down the Revolution road is a bit of a minefield due to various problems.
SO
Has anyone any further suggestions as to what will actually fit.
mk1rally
Post by mk1rally »
Not quite the same...but.
The Techdel/Deltech (?) minilite does fit over the minisport 4 pot on a 7.9 vented disc. This is the later ones though, post early 2000 ish as they did change the casting from the early ones.
I know this because that is what I am running. Mine are the 5 x10 but I also know the FIA 4.5 x10 (S offset) does too.
Like I said though, minisport calipers.
bluemin
Post by bluemin »
Thanks mk1 rally. I think that the Minisport calipers are a tad smaller although just how much smaller I've been unable to ascertain. I was somewhat hopeful of getting a few wheels without lashing out for the Minilites.
Thanks JCT ONE...........A check with Revolution however shows that they don't do a 5 x 10 unless it's their "8 spoke classic" [Minator I think] They do do a 6 x 10 in their 4 spoke range but only as a road wheel. :geek:
So there we are...........no further forward really :? :? ...........and I REALLY DID want to get the Minilifes with the BIG discount. :)
Dino
Post by Dino »
bluemin wrote:...A check with Revolution however shows that they ... do a 6 x 10 in their 4 spoke range but only as a road wheel. :geek: ...
Hmm, If you want a set of these you can have my mates, brand new never used! We've both given up trying to fit tyres onto them, they are a nightmare.
Vegard
Post by Vegard »
Why do you want to use 5" wheels?
bluemin
Post by bluemin »
Thanks Dino for that info. I've got four wheels like that already [make unknown] so I don't really want any more. Makes changing tyres on a rally nigh impossible.
Five inch..........well the Minilites I've got are five so I don't really want a mix & match set. If forced however I might go for six.
At the moment my idea is:
1) Six 5 x 10 Minilifes........IF THEY FIT
2) Two 5 x 10 Minilites
That would give me a dry set & a wet set with spares.
Might however go for the above but in six inch. The car does have arches & isn't strictly to historic regs.
