anything is possible, but i suspect that getting a cast iron ring made and machined to such a small size, then fitted to a set of 40 year old alloy brake drums will be, shall we say, a little expensive.
you can get this done for the larger prewar cars - it aint cheap for them!
The cast iron linning in a Minifin is not an insert, it is actually cast in place. To "recondition" them by replacing the iron lining entirely is impossible, but as has been said above a skim as thin as possible to clean the liner up would be worth a try. This was actually a mod in the day to improve braking by increasing the area all be it very slightly.
mk1 wrote:The cast iron linning in a Minifin is not an insert, it is actually cast in place. To "recondition" them by replacing the iron lining entirely is impossible, but as has been said above a skim as thin as possible to clean the liner up would be worth a try. This was actually a mod in the day to improve braking by increasing the area all be it very slightly.
I can't see taking a few thou. off be of any benefit what-so-ever. " very slightly " would be an over statement.
