'S' Speedos
ianh1968
'S' Speedos
Post by ianh1968 »
I've often wondered how many different variants of 'S' speedo have
been produced...
I have two, which are slightly different, they both are fully numbered
from 20-120mph.
The one in the Mini has:
Gear I = 42
Gear II = 60
Gear III = 83
The Marcos one has:
Gear I = 33
Gear II = 55
Gear III = 78
All figures are approximate...
Can anyone identify these for me?
I have also seen speedos with only 30-50-70 etc on them, the same as
those as sold by MiniSpares Centre. I much prefer the look of the fully
numbered faces and I have bought the 30-50-70 type a couple of times
and replaced the faces with my old ones.
Any information would be appreciated.
LarryLebel
Re: 'S' Speedos
Post by LarryLebel »
The crucial number is the turns/mile number after the serial number. 1280 is for a 3.44 diff and the higher numbers are for higher diff ratios. The speed 'marks' would be different for each speedo. I would guess there is a speedo for every stock diff ratio.
graham in aus
Re: 'S' Speedos
Post by graham in aus »
Confused by this one!
120 speedo, as per 970, 1071, early 1275 etc.
BUT has oil pressure / filter lights at 9.00 and 3.00 O'clock and voltage regulator on back.
Centre has numbers 4417 / 00 1376
Were all Early S speedos that stop at 120 (dead) non instrument voltage regulator type? :geek:
carbon
Re: 'S' Speedos
Post by carbon »
Ian,
The speedo in your Mini looks like it has the gear change points marked for the close ratio gearbox (normally straight cut). Is this what you have fitted?
ianh1968
Re: 'S' Speedos
Post by ianh1968 »
carbon wrote:The speedo in your Mini looks like it has the gear change points
I had wondered if this was one of the possibilities...
This is really good as this car does have an SCCR box.
The box is a 5 speeder, however, originally the MiniSpares
ST gearset which had about 0.877 as 5th. With a really close
5th like this, it was more of a 4.5 speed box...
I rebuilt the box a couple of years ago using a new Clubman
set, but retaining the 5th gear pair from the previous ST set.
I have ended up with a really nice proper 5 geared setup.
Code: Select all
    Ratio    Mph Change/Drop Overall
1st 2.583	 6.7               32%
2nd 1.711	10.2  66% = 2/3    49%
3rd 1.250	13.9  73% ≅ 3/4    67%
4th 1.000	17.4  80% = 4/5    83%
5th 0.833	20.9  83% = 5/6   100%
On the now "no-longer-available" ST set, the 5th gear driving
gear was 27 teeth vs. 26 teeth for the now current Clubman set.
rich@minispares.com please note! : -
For road use, this combination of Clubman + ST 5th is fantastic...
Please get the 27 tooth gears re-done so I can make another
box the same.
