Any Weber Guru's out there
pad4
Post by pad4 »
The trip to Blyton showed a massive flat spot under heavy acceleration in my car, ive never noticed it before
Trying to pull off the line it showed a flat spot , And just after a gear change (around the 5500- 6500 rpm range) there was a massive nothing then all was ok again.
Theres no misfires or starvation all the way up to 8000rpm , just that huge flat spot as described after you plant your foot down again following a change (doesnt do it lower down the rev range)
FYI - Arden 8 port running twin 40 DCOE's
Any ideas what it may be ??
Pad
Astro
Re: Any Weber Guru's out there
Post by Astro »
Hi,
I have a similar engine. What kind of sparc plugs do you use? What is their colour? What ignition time at 6000?
Smiffy
Post by Smiffy »
I'd be looking at the progression circuit first, which means changing the idle jets. What have you got fitted now ?
tomkidd
Post by tomkidd »
PAd,
There is a guy in Scorton called Paul Gardner who is very good with webers and has a rolling road.
http://paulgardnerengineering.com/
Pete
Has thanked: 57 times
Been thanked: 147 times
Post by Pete »
Peter Morgan would also sort it out on the rollers I'd have thought. (Wrexham)
JC T ONE
Post by JC T ONE »
Have you checked the diaphrame in the accelaration pumps ? Also I think there are separat jets for this in a weber ?
Astro
Post by Astro »
http://tr3a.info/WeberDCOEinfo.htm
OK, it's not mini but a lot to learn and it is no Advertising! 8-)
pad4
Post by pad4 »
Yea i think its a trip to the rollers - I can mess with an SU but ive never messed with a weber , best leave it to the pro's i think
Ill report back
Pad
251 ENG
Post by 251 ENG »
Southam mini metro centre 01926 815681
We have done a few 8 ports with webers and taps , sorry I mean amals :D :D
pad4
Post by pad4 »
Sadly wrong end of the country or id pop in for a cuppa
Got it booked in at Ric Wood in Stockport for a sesh
pad
251 ENG
Post by 251 ENG »
No problem , he,s really good from what I here , does a lot with Ford V6,s .
That where are rollers came from :D
