Any Weber Guru's out there
- pad4
The trip to Blyton showed a massive flat spot under heavy acceleration in my car, ive never noticed it before
Trying to pull off the line it showed a flat spot , And just after a gear change (around the 5500- 6500 rpm range) there was a massive nothing then all was ok again.
Theres no misfires or starvation all the way up to 8000rpm , just that huge flat spot as described after you plant your foot down again following a change (doesnt do it lower down the rev range)
FYI - Arden 8 port running twin 40 DCOE's
Any ideas what it may be ??
Pad
Pad
Re: Any Weber Guru's out there
Hi,
I have a similar engine. What kind of sparc plugs do you use? What is their colour? What ignition time at 6000?
I'd be looking at the progression circuit first, which means changing the idle jets. What have you got fitted now ?
- tomkidd
PAd,
There is a guy in Scorton called Paul Gardner who is very good with webers and has a rolling road.
http://paulgardnerengineering.com/
- Pete
- Has thanked: 58 times
- Been thanked: 147 times
Peter Morgan would also sort it out on the rollers I'd have thought. (Wrexham)
Have you checked the diaphrame in the accelaration pumps ? Also I think there are separat jets for this in a weber ?
- pad4
Yea i think its a trip to the rollers - I can mess with an SU but ive never messed with a weber , best leave it to the pro's i think
Ill report back
Pad
Ill report back
Pad
- Been thanked: 6 times
Southam mini metro centre 01926 815681
We have done a few 8 ports with webers and taps , sorry I mean amals
- pad4
Sadly wrong end of the country or id pop in for a cuppa
Got it booked in at Ric Wood in Stockport for a sesh
pad
pad
No problem , he,s really good from what I here , does a lot with Ford V6,s .
That where are rollers came from
