Weber 45
Gareth Brandt
Weber 45
Post by Gareth Brandt »
Hi. Got two Weber dcoe 45s. One nr 13, Italian and one nr 152, Spanish. Which one to use?? Read about bad progression hole placement on the 152?? Anyone got any info? Also heard that nr 15/16 are the best to use on a A engine, is this so? The engine the Weber is going on is a 1380, ported head, free flowing exhaust, race cam. Appreciate help and info :)
Gareth
Smiffy
Re: Weber 45
Post by Smiffy »
The 13 as the 152 has a different progression drillings, which make setting it up right a pain in the arse.
Gareth Brandt
Re: Weber 45
Smiffy wrote:The 13 as the 152 has a different progression drillings, which make setting it up right a pain in the arse.
So does the 15/16 work better? Or is the 13 better than the 152?
Gareth
Smiffy
Re: Weber 45
Post by Smiffy »
To be honest any that isn't a 152, would be good. Apparently the later 152G, made in germany solved the problem with a extra progression hole. The correct 45 for the Siamese port A series is the '45dcoe 9', which you can buy new again as they've started reproducing them.
ivor badger 2
Re: Weber 45
Post by ivor badger 2 »
Smiffy wrote: The correct 45 for the Siamese port A series is the '45dcoe 9', which you can buy new again as they've started reproducing them.
No it's not, the 13 is the siamised port carb and was originally bought by BMC for MGBs. The 9 went on big Healys with one choke per port.
Smiffy
Re: Weber 45
Post by Smiffy »
I stand corrected.
Gareth Brandt
Re: Weber 45
So, is the 13 good for an A engine?
Gareth
swifty
Been thanked: 12 times
Re: Weber 45
Post by swifty »
I've had a set of split 45 s and they were made from 152 . I think they run better low down and could them to tick over reasonably well with a 649 cam . 1480 cc . ... Ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
ivor badger 2
Re: Weber 45
Gareth
That's what it's designed to work on, so yes.
Smiffy
Re: Weber 45
Post by Smiffy »
swifty wrote:I've had a set of split 45 s and they were made from 152 . I think they run better low down and could them to tick over reasonably well with a 649 cam . 1480 cc . ... Ken
Interesting are they the later german versions with the extra progression holes ? If not where have you set the air bypass screws ?
swifty
Re: Weber 45
Post by swifty »
Smiffy there long gone , so can't answer that one ... Ken
Porsche 997 turbo S
I am from Essex
Smiffy
Re: Weber 45
Post by Smiffy »
swifty wrote:Smiffy there long gone , so can't answer that one ... Ken
Shame cheers anyway.
