converting drum brake to disc brake at front wheel
pad4
Re: converting drum brake to disc brake at front wheel
Post by pad4 »
Be carefull if you made your own pipes - quite a lot of these DIY pipe flaring kits dont produce the proper flares even if they look it
the flares are a precision part and theres only sykes pick and another make that supply proper flaring kits ( I used to sell Sykes Pic tools and did all the training on these things)
pad
goff
Post by goff »
That pipe looks to be steel ???????, that's probably why its leaking , get a new one made from proper material that's softer and will seat better
Goff
Has thanked: 125 times
Been thanked: 34 times
pad4 wrote:Be carefull if you made your own pipes - quite a lot of these DIY pipe flaring kits dont produce the proper flares even if they look it
pad
+1 on this. I've seen it more times than I care to count.
The other thing I've seen is some of the newer MC's are drilled too deep and so the hex of the tube nut contacts the top of the MC before it applies pressure to the flare of the tube, however it appears you are using your original MC. I've also seen a few tube nuts that are too short and end up with the same problem.
Smiffy
Post by Smiffy »
Spider wrote:The other thing I've seen is some of the newer MC's are drilled too deep and so the hex of the tube nut contacts the top of the MC before it applies pressure to the flare of the tube, however it appears you are using your original MC. I've also seen a few tube nuts that are too short and end up with the same problem.
Or in other words when people fit the wrong one.
Smiffy wrote: Or in other words when people fit the wrong one.
Actually Smiffy, no. I've found a few MCs (and flexible hoses) that have been drilled too deep and as for the Tube Nuts, as far as I'm aware, all UNF Tube Nuts are (supposed to be) made to the same Standard, I have seen quite a few in recent years, supplied under the correct P/N (P2845) but too short.
More a case of supplied lesser quality parts ;)
matic
Post by matic »
hi sirs,
i just got a set of brake/clutch pipe for master cylinder from mini spares today. i am just wondering tgat the head of the pipe is correct or not. it is double flare, not bobble flare. it it usable?
regards
ink
Smiffy
Post by Smiffy »
Had on several occasions, calls from irate mini owners. Telling me there professionally made brake pipes don't fit, when I've actually seen the part it's been too short. Whether or not there chinese shite, i don't know. But it should be obvious that a fitting that bottoms out won't work. Usually end up making them a new pipes to fix the problem.
rich@minispares.com
Post by rich@minispares.com »
you can get long and short unf and metric tube nuts
it can be a real pain!
'long beard boss'
1071 S
Post by 1071 S »
Check the non return valve first. A few years ago an acquaintance (who runs a prefessional brake shop) did stainless sleeves for my S mater cylinder. He was very proud to throw in a brand (NOS) kit still in its Lockheed box. First time I pressed the pedal the brakes locked on.. and continued to do so.
After much pfaffing about we realised that valve in the brand new kit was missing the required hole....
Luckily I still had the old bits so was able to mix'n'match a kit that has worked fine for years...
Cheers, Ian
matic
Post by matic »
hi sir,
thank you for all comments.
by the way, i have received the confirmation from mini spare that all pipes from them are double flare head. thus, can you please confirm me that it will be fit to the master cylinder? this is because i remember that the original pipe is bobble flare.
warm regards
ink
rich@minispares.com
an 'op2' flare will fit fine into masters and what not that have a male fitting - a lot of cars use them like this.
'long beard boss'
matic
Post by matic »
hi
thank you so much
i will try to check every thing, bolt the pipes and re-bleed the system again.
thank you all again
regards
ink
Has thanked: 4 times
Been thanked: 17 times
Post by Tim »
Its not a bad idea to bleed the master cylinder first before connecting the pipes.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
I was trying to see if I had a pic of an MC that had been over-drilled, but I don't seem to have one, however, here's a new hose, with the original type tube nut;-
