Brake and clutch pedal bush fitting
Lakeland997
Post by Lakeland997 »
I've fitted new bushes (Minispares 2A3034) to my pedals but the shaft won't fit through any more.
Does anyone know if they normally need to be reamed to size?
Been thanked: 10 times
Re: Brake and clutch pedal bush fitting
Nearly all bushes should be reamed before assembly.
I suspect (but don't know) that you would need a 9/16th's reamer.
Smiffy
Post by Smiffy »
mk1 wrote:Nearly all bushes should be reamed before assembly.
After fitting to take them back to the correct size.
I meant re assembly of the component, not the bush.
Of course the bush can only be reamed once it is fitted.
