I've fitted new bushes (Minispares 2A3034) to my pedals but the shaft won't fit through any more.
Does anyone know if they normally need to be reamed to size?
Brake and clutch pedal bush fitting
- Been thanked: 10 times
Re: Brake and clutch pedal bush fitting
Nearly all bushes should be reamed before assembly.
I suspect (but don't know) that you would need a 9/16th's reamer.
After fitting to take them back to the correct size.mk1 wrote:Nearly all bushes should be reamed before assembly.
I meant re assembly of the component, not the bush.
Of course the bush can only be reamed once it is fitted.
