Rear quater seal problem
Charlynsane
Post by Charlynsane »
Hello
I have a little problem on my baby mk1,
Whatever I do, there is a little space beetween the seal and the rear quarter window,
As for me the seal is correctly fitted, and this is the good seal
Here we have some pictures of the problem
window open
Uploaded with ImageShack.us
The window closed
What's happening?
I tried to adjust t but, It never close correctly,
Thank you for your help
Charles
pad4
Re: Rear quater seal problem
Post by pad4 »
Is it a new seal that you have got - Just had this exact problem with a friends car - threw the seal away and put an old one back on -the new seals are not profiled correctly or to stiff....
Just an idea
Pad
ricardo
Post by ricardo »
How's the hinge on the front? About to break? I had to trim the seal lip on the hinge area so my windows could close well - similar problem but I was more worried about the hinges breaking.
Benny
Post by Benny »
ricardo wrote:I had to trim the seal lip on the hinge area so my windows could close well - similar problem but I was more worried about the hinges breaking.
I've done the same.
guru_1071
Post by guru_1071 »
I've done the same.
trimming the seal around the hinge was something that was done in the 1960s to help with this problem, ive seen a couple of 'barn find' cars that have had this done
Charlynsane
Thank you so much for your answers,
The seal is brand new
The hinge is really good,
So you seem to think that I need to cut it?
The seal may need to "running in"??
Thank you
guru_1071
Post by guru_1071 »
heres one that was cut in the 1960's
cant blame an aftermarket seal on this car! :lol:
Charlynsane
It's really odd..
Do you think my seal is well fitted?
maybe in the bad direction?
It comes frome minispares, maybe a bad repro?
Charlynsane
ohhh my god.. the hinge broke during dismantling...
I was crying like a baby..
anyone has a rear quarter frame?
heelllppp
Benny
Post by Benny »
guru_1071 wrote:
Charlynsane wrote:
heres one that was cut in the 1960's......cant blame an aftermarket seal on this car! :lol:
That exactly how I cut mine.....glad to see there is a precedent for what I decided to do!
Charlynsane
anyone has a LH quarter light frame for sale?
Charlynsane
It seems to be easy to replace the hinge, anyone got this?
Charlynsane
Hello
I finally put mk3 rear quarter window seal
mk1 repro seal are very bad,
Now it closes perfectly!!
and the hinge is repaired!
I stole a hinge on a mk3 rear quarter window frame!
thank you for your help!
sandman
Post by sandman »
This is something I have considered myself.... but never got around to check.
What exactly is the diff between Mk1/2 and Mk3+ seals - other than the size that is..?
And if Mk3 seals fit... why even bother trying to use Mk1/2 types?
Also - what about door seals? Will a Mk3 or later seal fit a Mk1?
Cheers,
Ed_
Charlynsane
Dear Sandman,
In my opinion:
1)quarter seal
You can put the mk3 seal on mk1/2/3
It fits perfectly,
The mk1 seal (repro) doesn't allow the window to close properly,
2) Door seal
You have to put mk3 seal on all cars with internal hinges
You have to put mk1/2 seal on car with external hinges, they are a little bit difficult to fit, but it's a good repro, even though the rubber isn't very supple..
pad4
Post by pad4 »
There are 2 different types of rear 1/4 window seal on a mk3 , my early 70 car has rather thin flimsey seals but my later car 72 has thicker seals - ill take some piccys
Charlynsane
Yes exactly,
But when you want to buy repro during a restoration,
you only have two choices, isn't it?
