Standard steel wheel brake clearence.
Mark1Peachey
Post by Mark1Peachey »
Can a standard 10" steel wheel be fitted over 7.5" cooper "s" disc brakes? I wish to use "s" disc brakes on a morris mini minor but retain standard wheels and wheel trims.
1071 S
Re: Standard steel wheel brake clearence.
Post by 1071 S »
Some will tell you you can - but I have never (sic) found a set that will rotate when bolted over S calipers.
This leads me to believe there are (at least) two different specifications for "standard" steel wheels....
Cheers, Ian
cheleker
Post by cheleker »
Having been brought up on early 3.5" wheels (non-S), I learned that they would not clear S calipers. Years later I got in a "discussion" with some know-it-all who insisted they all would fit. Turned out we were both wrong. Some do and some don't with later wheels (70s+) most likely to fit. A while back I went through about 20 different 3.5" wheels and seven fit the S calipers I was testing them against.
Been thanked: 10 times
I have also found the above to be true. Some will & some won't. But they nearly all will with a 3/8" spacer. This gives enough clearance for them to fit over the callipers but they don't stick out too far from the wheel arches.
Lord Croker
Post by Lord Croker »
My standard 3.5" wheels have been used with 7.5" Cooper S disc brakes without the need for spacers. there is probably some truth in the fact that later wheels will fit, mine are 1981.
KJW
Post by KJW »
I had a similar problem with rose petal wheels on my Historic, and my calipers have been ground down. To give more clearance you can fit a washer between the caliper and the hub to add a little more space.
