I have a Mk4 with wooden steering wheel. There is the provision for a horn button. Is there a "slip ring" and contact available that can be fitted behind the boss to provide a connection to the horn button ?
Bob
Horn Button Mk4
- Been thanked: 10 times
Re: Horn Button Mk4
I think you would also require provision in the steering column - and that stopped after the Mk1. The horn contact and slip ring worked via the early indicator stalk.
I expect it could be done but I'm not sure it would be all that simple.
- timmy201
- Been thanked: 42 times
Re: Horn Button Mk4
How about a wireless button? This is a very cheap one but the idea might work
https://www.ebay.com.au/itm/373812416408
- Been thanked: 6 times
Re: Horn Button Mk4
hi tim
that is a sneaky idea but why not it can be put anywhere that is convenient
cheers roger
cheers roger
