mechanical fuel injection
minimad
Post by minimad »
I have always wanted to run a mechanical fuel injection system in my class of motor racing . TJ and lucas systems are impossible to find so when l saw a complete , running engine fitted with a slide throttle system and a kugelfischer injector pump l negotiated with the owner and bought just the injection system and 8 port head from him . However the pump is run from the front of the crankshaft with a toothed belt gear only and NO vibration damper . Have never run without a vibration damper before though have owned several engines that have run without them , one fitted with a 76mm gordon Allen crank which had a crack through a big end and the other a 1275 S block with S crank still in good condition . Personally l dont like running without a damper . but to be able fit one l would have to make a spacer to go between the damper and the pulley ..........what are your thoughts ??
MiNiKiN
Has thanked: 93 times
Been thanked: 31 times
Re: mechanical fuel injection
Post by MiNiKiN »
Congrats! I recently bought an almost complete TJ for very little money (- the HP fuel pump and the throttle bodies, though).
Still saving money to buy the ancillaries like Weslake head, engine and car around it :lol:
Cannot really help re the crank damper - personally I would rather have one fitted. Says my gut feeling!
The belt drive looks pretty oversized for the application, so you could possibly use a narrower belt drive on a separate pulley next to the crank damper. .
Oneball
Has thanked: 11 times
Post by Oneball »
You can run a two piece crank damper with a toothed drive. Others do them as well. I just picked the MS one for the pic
Exminiman
Has thanked: 58 times
Been thanked: 57 times
Post by Exminiman »
This might help, if you scroll down there is a slide assembly and a full TJ setup, bit dear, but looks like it may off been for sale for a while ?
https://www.historicracing.org.uk/parts/fuel.html
minimad
Post by minimad »
MiNiKiN wrote: Wed Dec 18, 2024 11:15 am Congrats! I recently bought an almost complete TJ for very little money (- the HP fuel pump and the throttle bodies, though).
Yes , l would much rather run with a damper myself but obviously the engine that the injection setup came from had no problems .
minimad
Post by minimad »
Yes , l quite agree with you , it obviously ran okay and without trouble .................l just feel a little uneasy not having a damper.........
